by stewart735 Investigator
Whats the data usage when using mobile as hotspot?
My home broadband is down (Virgin 😠😠) Whats the data usage when using mobile as hotspot for my laptop?
by Ace Contributor
Re: Whats the data usage when using mobile as hotspot?
HI @stewart735
TETHERING is free from ee.
It all depend how much data you have in your mobile allowance if it run off your data you need buy a add on.
You can check prices here
http://add-on.ee.co.uk/purchase
Make sure open that above link on mobile data not on WiFi.
Great answer @tahirmian
I hope this takes care of your questions @stewart735
Richard
