by Clare10
What settings should my phone have to use data allowance out with WiFi?
Re: What settings should my phone have to use data allowance out with WiFi?
Hi @Clare10
Welcome to the community.
What kind of phone do you have?
Are you just looking to use your mobile data?
by Clare10
Hi Chris I have an iPhone 6plus. I have been able to use the phone and everything else when I have WiFi. Without WiFi I can only phone or access things previously downloaded.
OK, thanks @Clare10
Could you please make sure mobile data is enabled in your settings:
Tap Settings > Mobile Data > switch Mobile Data ON.
If that's already enabled, please go to the add-on status page and let me know what allowances show.
