by ovdolfor
New Member
What's happened to my 10mb of data? As far as I know I don't use any data
Data usage says I have no data left from 10mb but I don't use any data
by Brilliant Contributor
Solution
Re: What's happened to my 10mb of data? As far as I know I don't use any data
Apps and phones can use data in the background.
I presume you mean 10Gb rather than 10mb as 10mb would be used in seconds
Solution
