by JimBobS
What is the maximum data you can gift from an unlimited data package
As the title suggests, what is the maximum data that can be gifted from an unlimited package? Can I say gift 2 x 100gb each month?
Re: What is the maximum data you can gift from an unlimited data package
@JimBobS   from a 4G unlimited plan you can gift up to 100 gig you must gift this first as the first 1 hundred gig of your limited plan is what you can gift.  If you use the 100 gig first yourself you will not be able to gift data.
Hi @JimBobS
It's detailed in the data gifting terms and conditions. Gifting is subject to fair use. How much data you have is irrelevant.
Gifting Your Data - Terms & Conditions
by JimBobS
Thanks.
Unless the terms and conditions have been updated since day 1, this appears to be the answer I was looking for.
Cheers.
J.
