by moonsaballoon Investigator
What does 4G HS 10GB 30 mean on my bill?
Just want to know if this charge is for something requested personally or not.
by Profile closed
Not applicable
Solution
Re: What does 4G HS 10GB 30 mean on my bill?
Hello @moonsaballoon did you buy a 10gb 30day data add on through http://add-on.ee.co.uk last month? 🙂
by Profile closed
Not applicable
Solution
EE Employee
Hi and welcome to the Community @moonsaballoon
@Profile closed is correct on this one as the charge you have mentioned is for a bundle that has been purchased after your data allowance has been used up.
Is it yourself that uses the handset or another person?
Many thanks,
Lee
