Highlighted
New Member
What 4g data speed should I expect from EE assuming good zonal?
Highlighted
by Ace Contributor
Re: What 4g data speed should I expect from EE assuming good zonal?
Hi John and welcome to the community.
There is no simple answer to that question! The speed you can obtain will vary depending on a range of factors, including, but not limited to: deployment architecture, network load, presence of any faults, your device capability and your plan type.
Are you having any problems with your 4G?
