by casper1976
Websites do not load over 4G, various errors
Over the last couple of weeks, whenever I have tried to load websites over 4G they fail to load. Various errors show up when clicking on the Details part but basically over 4G they don't work. Over wifi it's fine. Technical Support just keep telling me to soft reset but I can't do that all the time, plus that doesn't always work. Have also tried a hard reset and still no good. Thanks
Re: Websites do not load over 4G, various errors
What phone or device are you using?
Are you pay monthly or PAYG?
EE Employee
Welcome to the Community @casper1976
Can you try editing the APN on your device with the following details;
Name Internet
APN everywhere
Proxy Leave Blank
Port Leave Blank
Username Leave Blank
Password Leave Blank
Server Leave Blank
MMSC http://mms/
MMS Proxy 149.254.201.135
MMS Port 8080
MCC 234
MNC 30
Authentication Type PAP
APN Type If you have choices select internet + mms otherwise type in *
If you're not sure how to do this - let us know what device you're using.
Thanks - Karen. Smiley Happy
by casper1976
Hi Karen
Many thanks for the info. I have accessed the APN area but all the fields are grey and are not allowing me to edit?.
I have a Galaxy S6
Neil
EE Employee
Morning @casper1976
No problem!
Does it allow you to delete that APN and set up a new one?
To add a new one go to:
  1. Tap on Settings > Mobile networks.
  2. Tap on Access Point Names.
  3. Tap on ADD in the rop right.
  4. Enter your APN settings (For APN settings click here)
Let me know how it goes!
