by EABowden Established Contributor
VoWiFi/VoLTE success story
I just wanted to register my appreciation of a service well done - for a change.
Today I started a call on wifi in my house, moved into my car and it switched to VoLTE almost seamlessly (there was a 2 second silence but the call didn't drop), then back onto the mobile network to end the call.
I wasn't aware VoLTE data calls could hand off to the mobile network
Re: VoWiFi/VoLTE success story
Thanks for the feedback @EABowden Smiley Happy
It's great to hear the service is working as it should.
by Skilled Contributor
Skilled Contributor
You can also test this by turning WiFi off and on during a voice call and watch VoLTE/VoWifi flicker between each other.
Probably a tad geeky, up there with having a cell-monitor app running as you travel around.
