Highlighted
Very slow everything on 4G
I’ve been struggling for months with really slow connection all the time on my IPhone XR.
Calls, apps, games, music, etc
everything just grinds to a halt when I’m not on Wi-fi.
If I search for something on google for instance.... it just thinks about it for a minute and then says “google.co.uk could not provide a secure connection”
i click reload a few times and it loads up the search results.
On my apps, even the EE app, I click on it to open and it just sits on a blank screen for a while and nothing happens.
If I close it and reopen it a few times, it sometimes loads up.
Just wondered if anyone had any suggestions of what it could be?
Highlighted
Solution
Re: Very slow everything on 4G
@RiggaTheMighty  on the device go to settings/General/reset/reset network settings. Your device will reboot and you will need to put your Wi-Fi password back on the device after this. Please try cellular data.
Highlighted
Solution
