by Number41
Very limited access on mobile data
Hi!
I seem to be having access issues with mobile data.
Using Iphone SE websites I can browse to my heart's content via work or home wifi simply won't open when using mobile data.
I simply get the message "safari cannot open page because it could not establish a secure connection to the server". The home & work wifi doesn't seem to have a problem with this.
I tried removing/refiiting sim, reset network but still the same.
I'm able to receive/send whatsapp, view some sites but not others.
Any help would be appreciated.
Re: Very limited access on mobile data
Hello there @Number41
Is this certain sites that will not work for you on data?
Can you access this link with WiFi turned off  http://add-on.ee.co.uk/
If so what data shows available?
Speak soon 🙂
by Number41
Hi!
Thanks for responding.
I think it was the content access selection -seems to be working ok now.
I could open that page -some pages, Rightmove, people's instagram account via web search, Crash.net seem to be ok.
However forums such as pinkfishmedia or whatsbestforum would not open.
Many thanks for your help!
I see @Number41
Glad you got this sorted 🙂
Come back anytime.
