by Paddysmith
VOIP - am I wasting my time with EE router?
I have seen a number of posts about this but am wondering if anyone has a definitive answer:- is there a provider who can get VOIP to work on an 4GEE router and/or does anyone know if the issue can be solved by using an alternative router with the EE sim (which allows better access to change settings?).
Any help would be appreciated.
EE Employee
Re: VOIP - am I wasting my time with EE router?
Hi @Paddysmith and welcome to the community.
Are you using any particular VOIP app in order to create the calls?
Many thanks,
Lee
by Paddysmith
Hi Lee - the application is called Horizon and provided by Windsor Telecom.  I understand the issue to likely be a result of not being able to turn off SIP ALG in the router.
Any ideas?
Paddy
EE Employee
Hi @Paddysmith
Are you able to pop the SIM into a phone and use your device as a tether to rule out what may be causing the issue.
Many thanks,
Lee
