by Mark88G
Using my phone in Mexico
Will I be charged extra for using my data and texts in Mexico I have unlimited calls and text and 20gb data a month
Re: Using my phone in Mexico
@Mark88G   If your not on a max plan then yes you will be charged. You can use THIS add on to keep costs down.   Please read all of it before adding this add on.
Hi @Mark88G
Welcome to the community. 🙂
As @Chris_B said f you're on an EE pay monthly Max plan (after 10 May 2017), you will be able to use your allowances while travelling in Mexico at no extra cost.
Otherwise, take a look at the page that he referred to for the roam further add-on or the roaming tool for other add-ons and prices.
Please text ROAMING to 150 to make sure your phone is set up for roaming before you travel.
