by maximlfc
Using mobile data abroad
Can I use my mobile data abroad?
by Profile closed
Not applicable
Re: Using mobile data abroad
Hello @maximlfc yes you can use data while roaming but you will need to buy a data roaming add on after you have landed by accessing this link using your phones data (not WiFi) connection. EE should send you a text message containing this link as soon as your switch your phone on abroad:
http://add-on.ee.co.uk
Here is a link to the EE roaming tool where you can check any charges and what roaming add ons are available for your chosen destination. :):
https://explore.ee.co.uk/roaming
by maximlfc
Do you work for ee
by Profile closed
Not applicable
No @maximlfc🙂
Hello there @maximlfc,
Welcome to the community.
I would also give us a call before you go to make sure Roaming is activated on your account.
@Profile closed very useful information above gives you everything you need to use data abroad.
Have a great time 🙂
