by Bill65
New Member
Using data in Spain
Hello I'm due to fly to Spain tomorrow me and my wife are pay monthly customers and was wondering if we used our mobile data abroad would we be charged for it cus I know sometimes it can cost a fortune to use ........ Any advice very much appreciated ...... Thanks
by Ace Contributor
Solution
Re: Using data in Spain
Hi Bill and welcome to the community
Spain is an inclusive destination so data is charged as in the UK up to a 15GB fair usage cap. So as long as you stay within your normal allowance or 15GB, whichever comes first, you will not be charged extra.
It is usually wise checking roaming is enabled on your account before going. The easiest way to do this is usually through texting roaming to 150 or calling 150.
Thanks,
Peter
by Ace Contributor
Solution
Thanks,
Peter
