3 weeks ago
I have found out that I have used supposedly used 80% of my data on an unlimited plan. I understand a soft cap of 1000GB is there, but I have only used 80GB since the start of the pack. I have been using it for tethering a fair amount, but there was nothing online stating that tethering had a soft limit, like gifting, of 100GB. I hope this is an error or I have made a ridiculous purchase...
3 weeks ago
@Stevem97 Yes that’s correct. You can gift up to 100GB but to gift 100GB you need to do that before you start using the data yourself as you can only gift the first 100Gb of your unlimited allowance. So if you use 50GB before you gift you can only then gift 50GB. So with you using 80% of your allowance tethering you’ve actually use 80GB of your 100Gb of gift able allowance.
3 weeks ago
@Stevem97 you’ll probably find that this is the 80% of that 100Gb you can gift.
3 weeks ago
So... The tethering counts as the giftable data? That was not what was stated. Anywhere. Many spoke of 12 devices, max, which is fine. https://community.ee.co.uk/t5/4G-and-mobile-data/4G-EE-Home-broadband-SIM-and-unlimited-data-SIM/td-...
And others saying that tethering uses the unlimited total. I.e. 1000GB https://community.ee.co.uk/t5/4G-and-mobile-data/Unlimited-data-plan/m-p/821376
https://community.ee.co.uk/t5/4G-and-mobile-data/Tethering-on-unlimited-data-plan/m-p/818260
So why would my gifted be being used up? Makes no sense.
3 weeks ago
Hi @Stevem97,
When using an unlimited plan, any data usage will decrement from your giftable allowance.
Find out more in Introducing our new unlimited plans.
Hope this helps.
3 weeks ago
Hi @James_B thanks for the response.
So, to say it simply - the first 100GB is giftable usage, but once that runs out I can continue to use the data personally, but just won't be able to gift it?
3 weeks ago
3 weeks ago
3 weeks ago
3 weeks ago
@Stevem97 If glad you understood it as I was stating to wonder if it was understandable. 😁
3 weeks ago
3 weeks ago - last edited 3 weeks ago
@James_B @chris
My wife has the unlimited data Plan and I transferred 40gb to myself at the start of the month (Day 0). It now states she has no data left (3 days left), even though she's on the unlimited account. I am very fortunate because I did not transfer 90gb at the start.
I tried to 'Gift data' but because she's on unlimited we're unable to do this.
@Brownishmonster Whilst I am not well-knowledged in this area, I believe it would mean that she has no gift-able data left. i.e. she won't be able to give you, or anyone else any more data until the month is renewed. This was what my question in this topic that I was implicating. Can she continue to use her data at all?
The unlimited data plan has a soft-cap of 1000GB per month usage - and the first 100GB is giftable, which on my app also shows that it is 80%+ used, which is a little misleading.
3 weeks ago
Thank you for your quick response, and my sincerest apologies for hijacking your thread. Perhaps I should have asked a separate question, I thought your question was related to mine. Guess I was too quick to post.
With regards to her being able to use the data, unfortunately not. She received a text last week saying she used 80% of her allowance but she didn't see it.
There could be the case she has used 1000gb or so, but that seems unlikely.
Many thanks again.
3 weeks ago
@Brownishmoinster No worries - I hope you find the answer to your query. It may be worth starting up another topic to have fresh traction for when, I assume, EE support will be active for tomorrow morning.
3 weeks ago
Thank you again.
I'll probably pop into the shop or call support. Their chat is supposed to be open until 11 (Fridays) but that isn't the case.
Many thanks again and I hope you will enjoy your weekend.
3 weeks ago
Ah, that's annoying.
And again, no worries - these things can be infuriating when things seem to go weirdly wrong.
I hope you have a good weekend also.
Subject |
