by Jpmichaelson98 Investigator
Unlimited data plan
is the tethering limit 1000gb on this plan as long as it is less then 12 devices connected?
Solution
Re: Unlimited data plan
@Jpmichaelson98 : Yes, those are the limits for EE to not consider you are using it for business.
Solution
