by Usmansaeed Investigator
Unlimited data issue
I have the unlimited 4G data but yesterday i received message from ee you have used your data more than 80% buy more data. Why i am receiving this kind of messages although i have unlimited data. I didn't share my data as a personal hotspot. I am just using data in my phone as usual.
by Ace Contributor
Solution
Re: Unlimited data issue
Hi @Usmansaeed
Ignore that message that might be a system error.
You can always check your data here http://add-on.ee.co.uk/ where you can find the correct information.
6 REPLIES 6
by Ace Contributor
Solution
Hi @Usmansaeed
Hi @Usmansaeed.
Welcome to the community.
Have you recently upgraded to an unlimited data plan?
Jon
Yeah , i've used more than 100 GB data now all looks fine. You were right it was a system error message. Thank you
No, but its been sorted now. Thank you
by Skilled Contributor
Skilled Contributor
Only the first 100GB is eligible for data gifting on 4G unlimited plans so it's possible you had the message after using 80GB - ie the regular fair use text to illustrate that?
Glad this is now sorted for you @Usmansaeed
Thanks for coming back and letting us know.
Leanne 🙂
