Highlighted
Unlimited Data
Hi, I have an unlimited data plan, although I understand this only means I have 999GB of data, I was just wondering if there was anyway I can find out how much of it I’ve used? This is because I am using it to hotspot my laptop (as I don’t have wifi) so am worried it could run out?
Highlighted
by Ace Contributor
Solution
Re: Unlimited Data
Hi @ellastewart and welcome to the community.
The 1000GB fair usage policy is not a cap per se, you will still be able to use data after that but EE reserve the right to take action against those who take the biscuit.
If your laptop is Windows 10, you can go into
Settings -> Network & Internet -> Data usage, selecting the appropriate WiFi connection
and it will show you.
Thank you,
Peter
Highlighted
by Ace Contributor
Solution
Re: Unlimited Data
Thank you,
Peter
Highlighted
Re: Unlimited Data
Thank you Peter!
