by taz147 Investigator
Underground WIFI
Read more
EE auto connect & virgin media wifi won't connect
hi, i am registered for EE wifi but the auto connect never works and connects even though I am properly registered, sent the text to 9527.
I instead try the virgin media wifi option. The phone connects to the wifi but when I login, it says my details aren't registered, even though I get a new password sent to me each time.
Please help!
Solution
Re: Underground WIFI
Hi Chris,
Ok, so my issue was that I'd connected previously using whatever method I chose at the time. I "forgot" the network, added it again and I think it works. This morning I was at farringdon and was able to connect. I'll try again this evening and keep you posted.
Taz
10 REPLIES 10
Hi there @taz147
What phone are you using?
Has this worked in the past for you?
Hope to hear back from you soon 🙂
Hi Leanne,
It's never worked for me unfortunately.
I'm using Samsung galaxy S10.
Hope you can help!
Hi @taz147
Thanks for coming back to me.
Have you tried the below steps to see if you can connect to the London Underground WiFi?
  1. Once underground, turn on your WiFi
  2. Select EE WiFi-Auto from the list of networks
  3. Set the ‘access method’ to EAP
  4. Set your ‘EAP method’ to SIM
Thanks.
Hi Leanne,
How do I do that on the Samsung S10? I can't find the setting to do these changes.
⁣Taz147
Hi @taz147
Are you on the underground at the moment?
When you are on the underground and select WiFi, you will have the option to select EE WiFi Auto and then you can select the access method above.
Thanks.
Hi Leanne,
I couldn't see that option when I connected to the network. I cant attach the screenshot to show you what I see on my phone but eap option is definitely not there.
Thanks,
Taz
Which station are you having problems at, @taz147?
Are you able to connect to any at all?
Solution
Hi Chris,
Taz
Amazing, @taz147.
That can be a neat little trick we can give to others having the same problem.
Hey Chris,
Definitely do because it took me a while to figure that out! But I do think it's done the trick!
⁣Cheers,
Taz
