by brbaje Investigator
Unable to VPN via tether device, returns an error stating UDP traffic is blocked
Currently unable to connect to my corporate VPN, from my tethered laptop. If I try to connect to the same VPN phone it connects successfully and I'm able to browse corporate resources.
I have disabled IP version 6, and tried both L2TP and are corporate VPN client both with no success.
I have tried Bluetooth, wireless and USB tethering all without success.
I was reading some of the previous posts related to this issue and it appears that your account can be flagged by your content filtering and block certain VPN clients.
Any support or feedback on this would be much appreciated?
Thank you in advance
Ben Bajek
Solution
Re: Unable to VPN via tether device, returns an error stating UDP traffic is blo
Sorry all, this was caused by a local network confict with a VMware host.
Is now working.
Thank you
Ben
6 REPLIES 6
by Prodigious Contributor
Have you turned off content filtering in your EE account (under my device section).
My corporate VPN works and we use a UDP VPN
If my answer has helped you then please give kudos by clicking the KUDOS button at the bottom right of this post.
If I have solved your problem then please click "Accept Solution". My Phone: Samsung Galaxy S6 edge - Android 5.1.1
Thank you for replaying, data content controls are set to full access within myEE
Ben
What device is being tethered (from)?
You mean OFF as in Switching Content Lock OFF or ON ?
Hi @brbaje,
Welcome to the EE Community.
Have you spoken to your IT department to see if they can help you get connected?
I'm not aware of any EE account settings that would prevent you from accessing a VPN.
One thing to check with them is if your VPN client support IPv6. If you are using an older version that only supports IPv4 it could be the cause of the issue.
Solution
Is now working.
Thank you
Ben
No problem @brbaje
Thanks for letting us know it's sorted. Smiley Happy
Recent solutions
