by wspencer Investigator
Twitter and Facebook messenger Apple iOS apps do not work over EE 4G
Using an Apple iPhone 6S on iOS 11.4.1
Some apps will not connect properly when only conencted to EE 4G, for example Facebook Messenger and Twitter, however there are others.
These apps work perfectly when connected on WiFi
It seems to be an SSL or certificate related problem, some other apps also have problems.
Please can you help, there are lots of other business apps that don't function for me when I am out and about that I need to use. It is not practical to have to wait until I can connect to WiFi to get some updates.
thank you
Solution
Re: Twitter and Facebook messenger Apple iOS apps do not work over EE 4G
So I requested EE turn off Content Control, reset network settings, turned off and on again, no change.
Then this afternoon iOS 12 became available for my phone - so I upgraded (from 11.4.1) and lo and behold the problem has gone away.
This has been bothering me for months, and now it is sorted.
iOS 12 has fixed it.
I'd be surprised. There are loads of owners of iPhones using such apps.
That is why I am asking for help, I can assure you that they are not working for me.
The apps work fine on a non-EE connection, work fine on Vodafone 4G but not on EE 4G.
So what setting or configuration could possibly be causing this?
The apps open and appear to work, for example I can get notifications, but I cannot then read or post new messages.
Is this a device setting (on current update of iOS on a current device, apps are updated) or a network setting, or something else?
thanks
Solution
Great news @wspencer Smiley Happy
Thanks for sharing the solution.
