by Ecb Investigator
Topped up but no data (iPad / data sim)
Hi, just recently got a new iPad and requested and installed a EE payg data sim, topped it up £25 using the top up card included with it but the EE app on the iPad shows a balance of £25 but 0 data left - what's going on?!
chris
EE Employee
Solution
Re: Topped up but no data (iPad / data sim)
Hi and welcome to the Community @Ecb
If the credit is on the account, please head over to http://add-on.ee.co.uk/purchase (while you are on data not wifi) and choose the bundle you would like.
Many thanks,
Lee
7 REPLIES 7
Try restarting the device and then check again.
by Ecb Investigator
No difference, it's not a network connection thing as the iPad EE app shows the correct balance but just 0 data (no wifi connection, so it has to be accessing mobile network).
Do I need to buy one of these 'packs'?- being an ipad I have no use for texts or calls though, I just assumed the entire £25 would become an amount of data, not that I'd have to waste half of it buying a 'pack'.
Didn't the data SIM come with a pre-installed pack?
by Ecb Investigator
EE Employee
Solution
Many thanks,
Lee
by Ecb Investigator
Thanks, that has eventually got me online - I was very close to throwing the thing across the room!!
Hopefully when I next need some data when away from home it won't be so much trauma!
Regards,
Hello there @Ecb.
Glad you got this sorted.
If you need anything further let us know 🙂
