by rachellamhy
There’s no 10gb data in SIM card which it claimed there was.
  1. It claimed I used up all the data but I used only 500mb but supposedly I have 10Gb of data
  2. theres no way to find out how to get my 10gb data back
  3. terrible experience in using EE card and would never recommend it to anyone
  4. please reply ASAP to change my mind.
7 REPLIES 7
by rachellamhy
I dun get the 10gb data from the sin cardboard I purchased and said I used up
It claimed I used up all the data but I used only 500mb but supposedly I have 10gb came with the SIM card which is terribly sucks.
by Ace Contributor
Re: There’s no 10gb data in SIM card which it claimed there was.
Good Afternoon @rachellamhy
Welcome to the EE Community,
I would recommend contacting customer services on 0800 956 6000 opt 2 opt 4.
by rachellamhy
And the phone number u gave me is incorrect? Cuz it keeps telling me I dialled the incorrect number
by Ace Contributor
@rachellamhy have you got access to a landline try it from there as it is a valid number.
Re: I dun get the 10gb data from the sin cardboard I purchased and said I used u
@rachellamhy  the sim comes preloaded with 500mg of data and should be on the  packaging on how to claim the free 10GB of data.
Try +44 800 956 6000 opt 2 opt 4.
Hi there @rachellamhy
Where did you purchase the SIM card?
Also, what pack do you have at the moment?
If you text BALANCE to 150, you will get a reply with your pack information.
Thanks. Leanne.
Recent solutions
