by JoeWedgwood
Switched PAYG Sim from iPhone to Sony Xperia, no data connection?
Hello, so recently my iPhone broke so I'm using my old Sony Xperia.
I switched over my PAYG which I initially got with a brick phone and just haven't bothered changing. I bought a £10 Everything Pack and I can call and text just fine, however when I went to use data, it did not work.
I checked my balance and I have 1024mb avaliable so it's definitley there and on top of this when I called 150 originally to top-up the Xperia, I was greeted with 'Hello. Welcome to EE iPhone Support'.
Could this be the cause of the problem? If so how can I resolve this? Thanks for your time.
Solution
Re: Switched PAYG Sim from iPhone to Sony Xperia, no data connection?
@JoeWedgwood  Please check that the APN setting are correct.  Use THIS to check.
Solution
Hello @JoeWedgwood.
Thanks for coming here.
What happens when you try and connect to the data?
Has the Sony worked for data on EE previously?
Thanks 🙂
by JoeWedgwood
It just says that no connection can be made, like as if I haven't got any data
Thanks @JoeWedgwood,
What happens when you click on this link, http://add-on.ee.co.uk/
You would need to turn off any WiFi connection.
Thanks 🙂
by Ace Contributor
@JoeWedgwood
May I know your phone model?
And also To make sure to Check in your phone settings turn your  mobile data usage on.
Many Thanks
