by whyte_rabbitt Investigator
Social media won't work on 4G
As of yesterday my Facebook, Twitter and Instagram will not work on 4G on my Samsung but they do on Wifi. Even if I type the web address in browser I get "This site can't be reached".
As suggested in other posts I checked the content lock is not on, I have reset my network settings, i have tried another access point, restarted the phone, turned mobile data off - pretty much everything and it still doesn't work.
Any suggestions?
11 REPLIES 11
Re: Social media won't work on 4G
@whyte_rabbitt   sounds like there is an issue for these apps as they are all owned by Facebook.
by Brilliant Contributor
Well, I have just checked and they all work for me on 4G, so not sure why some are having this problem, really strange.
Just one thing you could do, is in settings, click on the individual apps and see if mobile data is switched on for each one of the apps, although I would have thought in settings in general allowing mobile data, this should not have been an issue.
Good Afternoon @whyte_rabbitt
Are all apps up to date?
Have you been able to follow @Schockwave advice and ensure data is enabled in your phone settings?
Speak soon,
Katie 🙂
by Leigh1688 Investigator
This happened to me yesterday.
Log into your EE account and go to manage device. Change your content lock to 'Strict' and then reset it to 'Off' and then it should all work fine after that.
Not sure why it suddenly started happening but changing the content lock and resetting it seemed to work for me.
Let us know how you get on.
Regards,
Leigh
Thank you @Leigh1688 , for giving us this information, will now be able to pass this on to other users, who are having the same problem, does seem strange.
Thanks for the comments.
My content lock wouldn't change so I've call EE technical who have done this on my behalf and it's still not working.
Hi @whyte_rabbitt
Thanks for coming back to us.
This can take up to 24 hours to complete.
Have you restarted your device?
Leanne 🙂
I've restarted it multiple times today
Thanks @whyte_rabbitt.
Are you able to try and use the 4G again today and see if it's working for you?
Jon
Hi Jon,
Still isn't working. Restarted again this morning to check.
Thanks again @whyte_rabbitt.
I've sent you a private message to get some more information from you.
Please take a look and get back to me.
Jon
