by LakesDude
Social media not working on 4G
Hi
I've recently moved over to EE from Vodafone (ported number) - one issue is that I can't seem to get my social media apps working on EE 4G - when using wifi, all is fine.
Twitter/FB/FB Pages are behaving as if they have no data connection - but there is. All other apps are fine & working well.
Device has been reset - all apps are set to use mobile data - the social apps have been removed & reinstalled.
iPhone 7 / IOS 10.3.1
Carrier : EE 28.3
Frustrating - can anyone pls assist?
EE Employee
Re: Social media not working on 4G
Hi and welcome to the Community @LakesDude
This does sound very strange.
Please may I know if you turn off 4G and have 3G only does that help?
Many thanks,
Lee
by Star Contributor
Star Contributor
Hi @LakesDude
Also, check the following:
Settings > Mobile Data > make sure it's on, scroll down and check Social media apps and ensure the slider is set to on.
Thanks,
Martyn
Recent solutions
