by Mammy83
Skype problems
Have an S7 and last week Skype suddenly started having problems on mobile data. Constant message of 'connecting' but allows me to receive messages still however not able to send any. Works fine on WiFi. Problems observed with Instagram and Whatsapp as well.
Any thoughts on a solution? Already tried resetting the access point but did not solve it.
Solution
Re: Skype problems
@Mammy83  : Could be your Switching Content Lock OFF or ON . It is switched on on new & upgraded contracts & seems to affect social sites. If just switching it OFF doesn't help, try switching it to STRICT, reboot your device and then switching it to OFF. That is seeming to do the trick.
Solution
Re: Skype problems
by Profile closed
Not applicable
Re: Skype problems
Hi @Mammy83
Login to your online EE account and change the content lock from off to STRICT then restart your device then turn your content lock back off this should fix your issue(s)
BustaCrabb
