by Brewsi Contributor
Since coming back from holiday I can not use 02 Wifi in costa
Came back from holiday in Canada last month and on visiting my local Costa coffee (regularly go there and have had no trouble before) can not get on to the 02 wifi, tried rebooting the modem and my phone but still no go...
Solution
Re: Since coming back from holiday I can not use 02 Wifi in costa
Thanks for trying this @Brewsi
Have you tried a network reset on the device?
This will remove all WiFi passwords you have stored.
To do this go to Settings > General > Reset > Reset Network Settings.
Let me know how this goes 🙂
8 REPLIES 8
Hello @Brewsi
Thanks for posting on the community.
What device are you using?
Does the device connect to other WiFi services ok?
Thanks, Leanne 🙂
my phone is a apple IPhone 6, latest update and dose connect to other WIFI just stopped working at costa's on there 02wifi
Tell the phone to Forget the O2 network in Costa & then try to connect again. You may have to fill the form that it presents in again.
Thanks @XRaySpeX
Let us know how this goes @Brewsi
Thanks for the information but tried that and still not go - did not even get the 02 registration page....
Solution
Hi
yes resent the network settings and still no go, even reset the modem and the network setting at the same time.
guess just have to put up with it.
Hi @Brewsi
If all other WiFi connections work this is not the device.
Did you speak to Costa and see if anyone else has reported issues?
Thanks 🙂
