by JACKSON1 Investigator
Shared data
Hi All,
I’ve got 2 plans on my 1 account. An iPhone 7+ and an iPhone X.
I have 10gb of data on my iPhone 7+ plan and 100gb on my new iPhone plan. This should be shared between my two devices but my iPhone 7+ is now not connecting to the internet as it has used up its 10gb.
Why is it not sharing the other 100gb from my other plan?
Cheers
Solution
Re: Shared data
@JACKSON1  These are not shared tariffs as they have their own allowances.  A shared tariff is only one allowance that both or more devices can use.
 But you can gift data to the other device.   Up date the my EE app and go to family usage.
9 REPLIES 9
by Ace Contributor
Re: Shared data
Hi @JACKSON1
You need to gift data to your other phone number.
You can find all details here How to gift data.
http://ee.co.uk/help/help-orphan-pages-/data-gifting
Many Thanks
Re: Shared data
@tahirmian Thanks.
Ive tried to follow those steps but there’s nowhere in the app that says Family Usage...?
And isn’t “gifting” different to a shared allowance?
by Ace Contributor
Re: Shared data
HI, @JACKSON1
Please update your app 1st. You can share your data with only share sim as your other phone already have Data you can gift your data from one to another one.
Solution
Re: Shared data
Re: Shared data
@Chris_B@tahirmian
Great. Sorted. Thanks guys.
I misunderstood what shared meant then.
Ive updated the app and gifted 20gb.
Thanks for the help.
by Ace Contributor
Re: Shared data
HI, @JACKSON1
No problem glad you sort out.
Enjoy your data on other phone.
Many Thanks
Re: Shared data
Brilliant work @tahirmian and @Chris_B
Great to hear you are sorted out @JACKSON1
Cheers
Richard
by Farra1981
Re: Shared data
I have this issue and don’t have family data on the app
Re: Shared data
@Farra1981  If you have more than one device on your account at the bottom on the left of the app you see this.
