by Mikaela88 Investigator
Server Dns address could not be found Sony Xperia z5
 I keep getting an error message saying server dns address could not be found when I try to use my mobile data to access the Internet on my Sony Xperia z5. My Facebook app and email app still works but when I try to access other Internet sites it comes up with this. How can I fix it please? Thank you
10 REPLIES 10
EE Employee
Re: Server Dns address could not be found Sony Xperia z5
Hello @Mikaela88
Welcome to the Community! Smiley Happy
To change the APN follow these steps;
  1. from the home-screen, tap on All Apps.
  2. tap on Settings.
  3. tap More.
  4. tap on Mobile networks.
  5. tap on Access point names.
  6. tap add at the top right of screen.
Then enter these settings;
Name Internet
APN everywhere
Proxy Leave Blank
Port Leave Blank
Username Leave Blank
Password Leave Blank
Server Leave Blank
MMSC http://mms/
MMS Proxy 149.254.201.135
MMS Port 8080
MCC 234
MNC 30
Authentication Type PAP
APN Type If you have choices select internet + mms otherwise type in *
Let me know how this goes!
Thanks - Karen. Smiley Happy
Hi Karen, Thank you for your speedy response! I have done this and so far so good! Hopefully it will continue to work as sometimes it drops in and out and doesn't consistently come up with the error message. Thanks again for your help. Smiley Very Happy
EE Employee
No problem @Mikaela88
Fingers crossed it does resolve it for good! Smiley Happy
Pop back and let us know if you have any other issues.
Thanks - Karen. Smiley Very Happy
Hi Karen,
Unfortunately the issue is back. I have tried adding a new APN as last time again but it isn't working.
Any advice greatly appreciated.
Thank you in advance
Mikaela
Sent from my Sony Xperia™ smartphone
Hi Karen,
My connection issues seem to be back again. My Internet keeps dropping out unless I use WiFi. I tried doing what you recommended before again but that hasn't helped this time. Do you have any other advice please?
Thanks in advance
EE Employee
Hi @Mikael88
Have you tried booting the phone into Safe Mode and seeing if this helps with anything.
Many thanks,
Lee
Hi Lee, I haven't tried that but I will and will let you know if I keep getting the issue. Do I need to keep it in safe mode or do I just need to do it once then go back to normal mode?
EE Employee
Hi @Mikaela88
I would try it for a couple of hours in safe mode, then pop out of it.
Let me know how you get on.
Many thanks,
Lee
Hi Lee, I have tried it on safe mode overnight and then gona back to normal and I am still having issues although now it is saying
unable to handle this request HTTP ERROR 503.
Do you know how to fix this?
Is this a phone issue or a network issue?
Mikaela
EE Employee
Morning @Mikaela88
Thanks for trying!
It could be either to be honest - I would be inclined to think it's a device issue.
If you can try your SIM in another phone and test accessing the internet - this will help rule out a device issue.
If it's still the same or you're unable to do this please give Customer Services a quick call and speak to one of the tech team.
Let us know how you get on!
