by lornajayyne111
S7 Edge - suddenly cant connect to net, insta, snapchat, fb. WHY?!
I can still get on Twitter, whatsapp, play music & some other random apps.  It was running fine until yesterday. I can't connect to wifi either - says no IP address.
I have tried restarting, tried the airplane mode thing. Tried uninstalling/reinstalling apps. Nothing is working. HELP?!
10 REPLIES 10
Re: S7 Edge - suddenly cant connect to net, insta, snapchat, fb. WHY?!
@lornajayyne111  If you can not get on wifi that's an issue with the router/ISP or your device not your EE account for your phone as wifi on the device has nothing to do with your EE tariff/contract
Hi @lornajayyne111,
Thanks for joining the EE Community. Smiley Happy
Just to clarify, are you having the same issue when connecting to both WiFi and mobile data?
- James
by Skilled Contributor
Skilled Contributor
Just focusing on the 3G/4G data issue, I am having similar issues and they are due to a mast in my area which is undergoing work. The result is that quite often I find I cannot access any internet services, and some other times WhatsApp and FB Messenger are working but everything else isn't.
I suggest you use EE's network checker to check if there are any problems in your area. If it doesn't show anything, contact chat or telephone support as they might know more than what the online checker shows (this happened in my case).
by Lukey90
Hello I just Registered here to ask the same question. Some websites services works some of them not somethimes it's just disconnect from everything like even London bus does work some of the dating apps can't access houseshare Web and many others. It's only issue on mobile data everything else works perfectly on my virgin broadband WiFi. Is it going to be fixed as this issue was following me for weeks! Pls
by ShaunHastings
Try changing your APN Setting to just IPv4 if you haven't already, had the same issue in that some apps would just not connect at all for almost 2 months and this was the only thing that fixed it, it's been fine since.
EE Employee
Morning @Lukey90
What phone are you using?
Have you tried following the advice given by @ShaunHastings ?
Thanks - Karen. Smiley Happy
by Lukey90
But how I gonna change it on my Samsung gs7 Edge? Can't find anything like that on Internet setting anywhere. Pls could you sent me step by step. Thanks
Skilled Contributor
It is in Settings / Connection / Mobile Networks / Access Point Names / Internet.
But @ShaunHastings mine is all grayed out and it doesn't seem like I can change it. I can add a new one though. Is there a way to change the default one rather than adding a new one?
EE Employee
Hi @Lukey90
If you follow the above steps and then add a new APN with teh following details:
Name Internet
APN everywhere
Proxy Leave Blank
Port Leave Blank
Username Leave Blank
Password Leave Blank
Server Leave Blank
MMSC http://mms/
MMS Proxy 149.254.201.135
MMS Port 8080
MCC 234
MNC 30
Authentication Type PAP
APN Type If you have choices select internet + mms otherwise type in *
Let me know if this resolves it.
@DonDino - once you add a new one you can then delete the current one.
