by R0ckst4r_31
New Member
Running out of mobile data
Since May I’ve been running out of mobile data each month.  Never had the problem before.  Any idea why?
Re: Running out of mobile data
Hi @R0ckst4r_31
The only idea I can suggest is that you are using it all.
There could be various reasons from the devices you are allowing access, to your viewing/data/app usage.
If this is predominantly a mobile phone data then check your data usage app under your phone settings.
Hi @R0ckst4r_31
Welcome to the community. 🙂
Take a look at our how much data am I using on EE article.
There's some brilliant information on there that can help you understand what data your phone is using and help you manage your data going forward.
