by Cc3200 Investigator
Rollover Data
If I have left over data, is that used before my new pack data or what?
Solution
Re: Rollover Data
Before! See How do I get Data Rollover from EE?
Your data allowance will be applied in the following order for each Pack: (1) Rollover data, (2) core pack allowance (3) Free Boosts.
If at the end of this pack period you still have some of the previous Rollover data left, that will not roll over to the next period, only the remaining core pack allowance will roll over.
by Ace Contributor
Re: Rollover Data
Hi @Cc3200
This is what EE says on the website concerning rollover data:
Data Rollover is a great benefit on EE pay as you go and Flex plans. If you haven’t used all the data in your monthly Flex plan or 30-day pay as you go pack, we’ll add it to the next one you buy so you get another chance to use it. If your next pack/ plan doesn’t start straight away, we’ll still add the leftover data as long as you start it within seven days.
All our Flex plans include Data Rollover.
Solution
Re: Rollover Data
