by Peter40
New Member
Restricted data why?
Seems I'm being treated as a minor I have restricted access why?
Solution
Re: Restricted data why?
Hi @Peter40
Try logging into your MyEE app then - Settings - Content Lock - change this to off. Then restart your device.
It should now work.
Thanks,
Solution
Hi @Peter40
It should now work.
Thanks,
