by Londonmandan Investigator
Removing IPv6
Is there anyway to remove IPv6 from my connection and just have IP4 as I am now unable to connect to my VPN from my iPhone 8.
https://documentation.meraki.com/MX/Client_VPN/Troubleshooting_Client_VPN#IPv6_and_Mobile_Devices
7 REPLIES 7
Re: Removing IPv6
Not unless there is something of that ilk you can change in the APN, usually APN Protocol.
Re: Removing IPv6
Where would the APN settings be and what am I changing them to?
Re: Removing IPv6
Hi @Londonmandan
I'm not aware of any way of changing the APN manually on an iPhone.
It may be worth having a chat with our Tech Gurus.
Let us know how you get on.
Re: Removing IPv6
Hi Christopher, I spoke with tech support on the phone yesterday and they pointed me here as there may be a work around to get an IPv4 address instead of a v6
Re: Removing IPv6
You are unable to update/change APN settings on an iPhone as these are locked out by the network. These are done by Carrier updates from EE.
Re: Removing IPv6
So I am pretty much screwed as far as getting IPv4 is concerned? Guess I will get on to Cisco
Re: Removing IPv6
Hi @Londonmandan,
I would definitely contact your VPN provider. I'm sure they'll have a product that is compatible with IPv6.
