Highlighted
by Investigator
Re: Routing between EE home broadband networks doesn't seem to work anymore
Same problem no remote access to my cctv cameras on 4G. Not going to muck about with EE I am changing my network whom I have been with for years and years.  I did t have EE broadband I have sky.
8 REPLIES 8
Highlighted
@Mellows: I think you could be up against a limitation of EE's mobile network. The EE mobile network uses Carrier Grade NAT (CGNAT), which means that you don't get your own public IP address but share it with other users. So you can't be uniquely id'ed on the Net & therefore your LAN cannot be addressed from outside for unsolicited accesses. This is unlike fixed BB.
Highlighted
by Investigator
Thank you for that info, so is there anything I can do to fix this
Sent from my iPhone
Highlighted
Can't Access CCTV over 4G
@Mellows: How are you trying to remotely access your CCTV currently? Who is its manufacturer?
Highlighted
by Investigator
Re: Can't Access CCTV over 4G
I can remotely access when away from home if I log on to someone’s wifi. I can not access the cameras via G4 mobile data..
I am using guarding expert app which work with my cctv dvd.
I understand this has happened in the past with EE customers.
Thanks for your help. I am not technically knowledgeable
Sent from my iPad
Highlighted
I'm trying find out exactly what you actually do to access your CCTV remotely. You cannot assume I would be familiar with this app. What do you have to feed into this app? Did you have to tell it the public IP of your home router at least initally?
Who is the manufacturer of your CCTV?
Highlighted
by Investigator
The video is Teknika. I have the IP address to access it when I am home and also I have an IP/domain address to access it remotely.
this system had been working for the last 2 years with out problem. Working from home and away from home on my iPhone 6via 4G.
In the last couple of weeks I can not access via G4(if I am in the street with no wifi access).
Please bare with me I am 68 years old and can’t understand what has changed. I have not touched any setting.
thanks
Highlighted
What is the IP/domain you use to access it remotely?
Highlighted
by Investigator
No I still have the problem. I even spoke to EE technical support who could not help.. I was hoping for a simple solution which I never got so I am going to leave EE after 35 years. Which I really did not want to do.
Thanks for your help though
