by lou7 Valued Contributor
Valued Contributor
Re: Hi I carnt get on the internet it justs says sbout blank or not a trusted ce
Hi can anyone tell me whats the best net work mode to be in please as only getting one bar of signal
19 REPLIES 19
Auto Connect.
Valued Contributor
Hi whats the bes network mode to be in I only have one bar of single on my phone
  1. Hi can some one tell me whats the best metwork mode to be in I only have one bar of signal I havr four opfions and yhere all letters I know lt etc is 4g bjt tjat only gives me one bar of signal tjen yjere others  and thers a  gsm only my phone is vsry slow   thankyou
Re: Hi whats the bes network mode to be in I only have one bar of single on my p
Hi @lou7,
You can set it to 4G and your phone will automatically switch to 3G if you lose your 4G signal.
Please let me know if you have any other questions.
James​​​​​​​
Valued Contributor
 Hi which one is that thanks
Sent from my Samsung Galaxy smartphone.
The 1 with LTE in it
Hi @lou7,
Can you list the options you see for me please?
Valued Contributor
Hi yes lte/wcdma/gsm      wcdma/gsm         gsm only
Hi @lou7,
Please select the lte/wcdma/gsm option.
Valued Contributor
Thankyou for your help really apreciated
No problem @lou7 Smiley Happy
You know where to find us if you need help with anything else in the future.
Thanks! You're welcome :)! Glad I could be of assistance & it is now sorted.
Valued Contributor
Hi can you tell me if downloading apps can slow your phone down and slow
the signal down please also when I try and go onto my ee app it closes
before I get a chance to view my bill or data or anything its says
unfortuantly my ee has stoped
Valued Contributor
Hi james the ptions I have got for network mode is lte/wcdma/gsm
(auto connect) wcdma/gsm(autoconnect) wcdm only gsm
only
Hi @lou7,
When your phone is downloading apps in the background it may affect your data speeds for other tasks.
Is My EE closing every time you use it? Have you tried deleting and reinstalling the app?
Valued Contributor
Hi yes ive tryed delet ing and reinstalling it also these arr my nstslrk
modes what ones best phones very slow always has one bar of signal for some
reason ??? Lte/wcdma/ gsm(autoconnect) wcdma/gsm
(autoconnect) wcdma only gsm only
Hi @lou7,
Lte/wcdma/ gsm(autoconnect) is the best mode to use.
Does the network status checker show any problems in your area?
Valued Contributor
No it doesnt
Hi @lou7
Thanks for coming back to us.
Do you get more than one bar in other areas?
Are you with us on pay as you go or pay monthly?
Speak soon, Leanne.
only
Use the "LTE/wcdma/gsm (auto connect)" option, both of which I pointed you at earlier.
