by Celyn1996
New Member
Problems with data allowance after upgrading
I have recently upgraded my phone and therefore have got a larger data allowance. My upgrade arrived last week and I’m using my new phone and sim but the new data allowance hasn’t renewed. When will the new data allowance be activated?
by Ace Contributor
Solution
Re: Problems with data allowance after upgrading
Hello @Celyn1996 you can check your plan and contract dates by logging in to MY EE online and navigating to MY EE>Plan & add ons:
https://id.ee.co.uk/id/login
Your upgrade can take effect either instantly or on your next bill refresh. 🙂
by Ace Contributor
Solution
Hi @Celyn
Please see the brilliant answer from @tm90
This explains exactly what the situation is.
Whatever you've upgraded to, I hope you are loving it.
Cheers
Richard
