by Skilled Contributor
Skilled Contributor
Priority of 800MHz 4G
For this week I'm based at a site where even EE's signal falters. EE's coverage map shows 'variable indoors coverage' for all kinds of signal (2G, 3G and 4G), quite patchy.
Trying to have a browse at lunchtime was a struggle. I kept looking at my phone rotating through modes, struggling to connect via 3G/HSDPA... nothing... then 2G/Edge... nothing again. When I looked at it a second time, I again caught glimpse of the same cycle, and only at the end of it, after about 2 minutes, it went to 4G 800MHz and stayed there hovering between 1-2 bars.
Now I know patchy signal on the map means there could be a few centimetres difference between signal and no-signal, but I'm wondering what's the order of preference?
In areas where 800MHz exists, is it / shouldn't it be 4G 800MHz above all others?
Solution
Re: Priority of 800MHz 4G
Hi @DonDino,
Not sure if you have seen this thread?
There are some good insights into how it all works, particularly @Peter_C's comments.
Hope this helps.
Solution
Hi @DonDino,
Hope this helps.
Skilled Contributor
Thank you @James_B, that's very helpful! The discussion you linked to is very informative!
EE Employee
