by zlez93 Investigator
Preferred network type??
What's the preferred network option here ? I typed *#*#4636#*#* to get into this screen on my android phone.
7 REPLIES 7
Re: Preferred network type??
Hi @zlez93
It's a list of the networks your device can connect (locally and roaming). Although this isn't necessary accurate as it's a generic list Android can connect.
Good Morning @zlez93.
Welcome to the EE Community.
What phone are you using?
Usually we'd recommend connecting to LTE/CDMA/UMTS auto unless there's a reason you're looking to change.
Jon
@Jon_K
It doesn't matter which network the OP chooses on this screen, as it doesn't save and will default to programmed firmware network selection.
Thanks for clarifying, @Northerner! 🙂
I didn't buy my phone from EE,
It's a Chinese phone Xiaomi mi 9
@zlez93   What that screen shows is the type of network connections that device has.  There is nothing you can do about changing the connection type as the device will pick the connection it needs so it can operate. It’s just a list and you don’t need to be accessing it.
Actually the screen you are seeing is preferred network type.
It actually is changing how the device is connecting to the network.
I switched from 4g to 3g using it.
