by vaibhav1608
Portgin issue from Lebara to EE
I ported my numbers from Lebara to EE. I got a message from EE that the porting is done, and although my outgoing from EE works now and it is from my original number, however I am not getting any incoming calls and they are still directed to Lebara's voicemail.
Re: Portgin issue from Lebara to EE
@vaibhav1608   Have you turned off and back on your EE device ?
by vaibhav1608
Just did, it doesnt help. If I call my number, it is still going to lebara voicemail. And if I call from my number (EE SIM), the caller id shows my original number (lebara one)
@vaibhav1608  It sounds like the port is not completely done.    Give customer services a call ( 150 ). And ask them to refresh your line.
