by thattechyguy
Port 554 / rtsp now seems to be blocked over the 4G?
Hello,
I have a CCTV system camera set up at home which is set up to stream to a mobile iOS app via port forwarding on ports 554, 80 & 8000 on my home router (Virgin). This works within the LAN perfectly and did used to work over the EE 4G network but all of a sudden, now bizzarely, this is now no longer the case.
I believe it is a case of EE blocking something as when I use a VPN on the same iOS device, the stream works as expected. Others on other networks (with an iPhone and the same app) can view this fine.
Can anyone advise what the issue is here?
Kind regards,
Re: Port 554 / rtsp now seems to be blocked over the 4G?
EE does not block any ports. You are up against a limitation of EE's mobile network. The EE mobile network uses Carrier Grade NAT (CGNAT), which means that you don't get your own public IP address but share it with other users. So you can't be uniquely id'ed on the Net & therefore your LAN cannot be addressed from outside for unsolicited accesses. This is unlike fixed BB.
by thattechyguy
Any ideas why it used to work and then all of a sudden stopped?
I can only access via a VPN which suggests that something has changed on EE's end as the set up has stayed the same for me and others who are not on the EE network can see the stream fine, by using the same app and login details without a VPN.
Not really! It might be something to do with IPv4 vs. IPv6.
