by Tricky1st
New Member
Poor service
For years I’ve been complaining to EE regarding the poor service I’m receiving, my calls near enough all
drop out and takes a few seconds like 10+ before I can ring the number again! I’m losing work due to this and it’s becoming very frustrating
6 REPLIES 6
Re: Poor service
Hi @Tricky1st.
Are you having trouble in one postcode or more than one place?
Have you had a replacement SIM card at any point?
Jon
by Basscube
Re: Poor service
I’m having exactly the same problem. Been happy with service up until a few months ago and since then it’s got absolutely shocking. Constant drop outs (called EE earlier to complain and dropped out after 30 mins I mean how ironical)
just getting fed up and won’t be going back to them ever again.
Re: Poor service
Hi @Basscube
Welcome to the community.
Are there any maintenance works in your area? You can check for, or report, a problem on our network status checker.
by Basscube
Re: Poor service
It’s not just my area though ?
Kind regards
Mark Bonar
Re: Poor service
OK, thanks @Basscube
You can check more than one area on there. You can search different postcodes of areas that you're having a problem in.
by PGC1 Investigator
Re: Poor service
I’m having exactly the same problem, the quality of 4G has dropped massively, most of the time I just about get a 3G signal... time to move to a better service provider maybe?
