by Fozzy2670 Established Contributor
Poor 4g signal
Terrible 4g been like this for weeks !!!
31 REPLIES 31
Re: Poor 4g signal
Hi @Fozzy2670
Have you checked EE network service checker?
Re: Poor 4g signal
Reset phone checked service tracker just rubbish service,
Re: Poor 4g signal
@Fozzy2670
So what did the service checker say? If there are no reported issues then report one via the checker.
Re: Poor 4g signal
Hello there @Fozzy2670
As @Northerner has advised you can report issues on the network status checker.
You can also get this looked into further by getting in touch with our customer service team.
Thanks, Leanne.
Re: Poor 4g signal
Had good speed for two days went into EE shop had 58mb download think they have a booster in shop !!! Helps to sell contracts I guess 100 yards from the shop 4mb
Re: Poor 4g signal
51097CEF-0095-4AF4-91EC-E64884F9D1DA.pngCrap!!!
Re: Poor 4g signal
Hi @Fozzy2670
I recommend following @Leanne_T's advice and speak to our technical support team.
by Star Contributor
Star Contributor
Re: Poor 4g signal
Hello, I've looked into the masts surrounding that location and they are 4G.
However, you are in cell edge of multiple sites which will be impacting performance. There is not much EE can do to resolve the radio environment quickly. However, ongoing capacity adds should help as and when they come.
Re: Poor 4g signal
So always going to have rubbish signal at that location
Re: Poor 4g signal
No point get the same advice or excuse ongoing maintenance reset phone reset network settings get sent new settings unless you live on top of a 4g mast it’s a crap service
Re: Poor 4g signal
5EA0D065-C413-418A-B00C-EC1846973936.pngUpto 60mb no chance unless you climb a 4g mast
Re: Poor 4g signal
Been onto EE done some settings changes even worse !!! 485304AA-B415-4E52-98FF-6723049EBEE2.jpeg
Re: Poor 4g signal
Which settings did you change, @Fozzy2670?
Re: Poor 4g signal
I did nothing it was all done from EE side
Re: Poor 4g signal
Ok, I suggest getting back in touch with our technical team to advise them that whatever they did, didn't work @Fozzy2670.
They'll be able to move on to the next troubleshooting step then.
Re: Poor 4g signal
Just the area I am in they say tried the old mast is down excuse if that was the case they would have a maintenance crew in this area 24 7 always get that excuse. Getting old and worn now, Would leave but have Apple Watch and Apple stupidly gave EE sole rights guess the paid the most.
Re: Poor 4g signal
@Fozzy2670  You couldn’t be further from the truth,  it’s the fact no other network can support the Apple Watch in the way it works with your account/number and calls/texts being directed to the watch.
Re: Poor 4g signal
They can’t offer me more than 6mb on 4g  and still expect me to pay the same price. Stuck with crap 4g if I want to keep watch.
Re: Poor 4g signal
When your quoted 72 hours I assume they mean working days?
Recent solutions
