by nataliateresa Contributor
Please help
When i arrive in my office for last 2 days i have lost internet connection. I have rebooted and everything nothing happens. When I leave for the evening and go a mile down the road it all comes back like nothing has happened.
PLEASE HELP, getting really  frustrated now
19 REPLIES 19
by Star Contributor
Star Contributor
Re: Please help
Hi @nataliateresa
Have you checked the network status checker to see if there is a mast issue near your work?
https://myaccount.ee.co.uk/networkchecker/checkservice
Also, is anyone else on EE having the same issue?
Thanks,
Martyn
Re: Please help
Heya,
i did, yesterday it said there was a fault and this morning i got a text to say it been sorted. But it happen again just did another log.
by Star Contributor
Star Contributor
Re: Please help
Hi @nataliateresa
It seems like another fault has developed.
Can you tell me which phone you have please?
Thanks,
Martyn
Re: Please help
Hi Martyn,
I have a Huawei Honor CHM-U01
by Star Contributor
Star Contributor
Re: Please help
Hi @nataliateresa
Thanks for letting me know.
In settings, network, is your phone set for 2G/3G/4G?
Thanks,
Martyn
Re: Please help
3G 🙂
by Star Contributor
Star Contributor
Re: Please help
Hi @nataliateresa
Do you have the option to select auto or 2G/3G/4G?  If so, please select auto or 2G/3G/4G then see if your signal improves.
Thanks,
Martyn
Re: Please help
Doesn't look it 😞 unless im going blind!
by Star Contributor
Star Contributor
Re: Please help
So you went into settings, general, more, network mode?
I don't have the same phone so I'm guessing where the settings would be.
Thanks,
Martyn
Re: Please help
Yes and it automatically says connected to EE wouldnt let me change the 3 to 4 G,
Appreciate the help
Re: Please help
Hi @nataliateresa
Thanks for posting 🙂
If their has been a service effecting fault that has been resolved, it can take 24-48 hours for service to fully resume (depending on problem)
Have you switched the handset off and on?
Fingers crossed your service will be back to 100% as soon as possible.
Richard
by Star Contributor
Star Contributor
Re: Please help
The poster's device is not 4G capable.
Re: Please help
I didn't know that @Peter_C so thank you for assisting.
In terms of service @nataliateresa have you had problems texting, calling or using the internet before the network fault?
If not, then I am confident service will restore soon.
Richard
Re: Please help
Thank you unfortunally, i've walked in today into my office and same issue 😞
Re: Please help
Hi @nataliateresa
Is it only in your office that you lose signal?
Richard
Re: Please help
Yes office and surronding, it did go for a few minutes  when i was in park near my house. but 100 my office it just came back for 2 seconds and has gone again. Not sure what happening as my friend on same network and she not got problems
EE did say there been double fault but got resolved
Re: Please help
Thanks @nataliateresa
Are you able to try the SIM in another phone at all?
This could be a SIM or phone fault that is causing this if other users on EE have no problems.
Speak soon, Leanne 🙂
Re: Please help
Got it looked in the shop, wasn't the phone but i did get told there was reports of other problems and it got back to normal today.
I don't understand why i should pay for last 3 days when the service failed on me?
But appreciate all the assistance
Re: Please help
Hi @nataliateresa
Thanks for coming back.
If you get in touch with our customer service team they will look at this for you.
Leanne 🙂
Recent solutions
