by mister_johnn Contributor
Phone signal and data connection in Surbiton?
For the last few days I can't use my phone around home (Surbiton) as I can't call anyone or have enough signal for data connection, what is happening? Had no issues in this area for a few years.
14 REPLIES 14
Re: Phone signal and data connection in Surbiton?
Hi @mister_johnn
Welcome to the community. Sorry to hear that you're having some problems with your signal.
Please check your area on our network status checker to see if we're aware of any problems.
If there's nothing listed, you can report a problem on there too, so our network team can investigate it.
by johnsmith1234 Investigator
There is a problem yes. It has been happening since 30th September / 1st October...
No data or calls whatsoever in the whole central surbiton area since and the problem is still ongoing.
Apparently the problem cannot be currently fixed because health and safety wont sign off on the mast site before they can get an engineer out to look at the problem.
I have been told that the current fix date could be by the 12th November!
Unbelievable...
Hi @johnSmith
Thanks for coming to the community and providing this information.
Have you been registered for updates?
Do you have a WiFi connection which will allow you to use WiFi Calling?
Katie 🙂
by Dred0702
New Member
I've noticed this too. Zero signal and data. Incredibly frustrating. Especially when trying to organise things with the family.
@johnsmith1234 how did you get info about the mast? Makes sense but would have been good to get this from EE direct. Very poor customer service.
I think Surbiton users should be compensated for being in the dark about this engineering work. Almost 2 months with no network?!
Hi Katie,
I have it enabled, but it just not working for me. Most of the time I have to use WhatsApp and use the internet from home by Wi-Fi or go towards Chessington, Kingston or Thames Ditton to make a call as not all my contacts are using WhatsApp or other social media apps.
It was nice from EE to send a message and say that they have an issue and they are working on a fix, rather than us (the customers) to chase what's happening and try to find a workaround until it is fixed. I have activated the EE update and received a message today saying that the masts need further investigation and the following update will be on 29 October.
I hope EE will have a compensation program for everyone affected as this is very frustrating and I need both phone and data signal to work at home and around due to my job.
johnsmith1234 ... 12 November? Nooooooooo! 😞
Dred0702 ... The compensation should be nice. Other networks gave compensation when issues occurred!
Thanks for getting back to me @mister_johnn
Finger's crossed it's not much longer.
What is happening when you try to use WiFi Calling?
Katie 🙂
@mister_johnnYep, really not good enough from EE. One mast covering entire area?! If I look at other masts in surbiton area from other networks there seems to be several (I might be wrong that there is only one mast from EE but if so, this is ridiculous and they should fix the problem as matter of priority)...most likely too busy focusing on 5g rollout to care. Someone from EE customer services actually told me that if you don't like you can leave the network and they will perhaps waive early contract exit fees - dreadful...
@Dred0702I spoke to EE executive complaints team
by Chris8williams8
New Member
Just moved to Surbiton and both me and partner are with ee and have no phone signal.
As per messages above, can EE representative give informative updates on what is happening and when it will be fixed?
Thanks to others for explaining
Good Morning and welcome to the community @Chris8williams8
If you would like to register for updates please visit the Network Status Checker
I would also recommend using WiFi Calling whilst this issue is being resolved.
Katie 🙂
by Philsmith87
New Member
Sadly it's been going on for about 2 months. They keep telling me that they are waiting for BT to fix the mast.
Call them up or go through live chat in your account and complain, sadly it won't fix problem but they will compensate you with free month or two depending how long you been suffering.
by Mar1506
Thanks - this is just what I needed to say bye bye to EE. I’ll switch to Vodafone.
I switched from o2 to ee, initially good in surbiton but the last 3 months have been awful and then to add this saga for the last two weeks with no signal/data whatsoever and the way they have handled it is utterly sh*te...all they say is use "Wi-Fi" calling blah blah blah. Bottom line is they don't care, and yes you should switch.
Hi all.
Thanks for your patience while this is being investigated.
As @Katie_B said earlier, if you sign up for updates on the network status checker, if you haven't already. We'll send you updates when we have them.
If you would like more information or to discuss compensation, I recommend speaking to our Technical Support team.
Thanks again.
by Fwellard
New Member
Absolutely agree. I can barely take calls or get network / data which is making things really difficult. I'll be switching network if this doesn't change soon.
