by srichardson95 Investigator
Phone keeps on saying 'searching' and won't connect to anything
My phone says 'searching' and has done for the past 24 hours. It will not connect to signal or data. I have tried removing my sim card and resetting etc. Can someone help me please?
15 REPLIES 15
My iphone 5s for the past 24hours has said 'searching' and will not connect to anything, so i have had no data or signal. I have tried removing the sim card, resetting my phone etc. but nothing seems to work. How can i fix this?
Re: Phone keeps on saying 'searching' and won't connect to anything
Have you checked the Network Status Checker  ?
Yes, apparently there are no problems in my area
Hi @srichardson95
Are you on PAYG or pay monthly? If PAYG when was the last time you made a chargeable call or text?
How long have you owned the phone and did you get it from EE?
@srichardson95  Have you tried a network reset on the device?
by Mikeyy247 Established Contributor
Hi have u tried giving the sim a clean then putting back in phone start up then switch off again.  Check the sim hasn’t any damage cos they are sensitive if nothing phone 150 or start a live chat.  Or if phone is unlocked try another sim in it to rule out damage to inside the sim tray
I am on PAYG. I do not know when I last made a chargeable call, probably a long time ago.
I have owned the phone nearly 2 years and yes i bought the phone from EE.
how do i do a netweork reset?
@srichardson95  Go to Settings>General>Reset>Reset Network Setting.  The device will re boot and you’ll need to put your WiFi passwords back on the device after this.
Ahh so looks like the sim will be cut off as you haven’t used it for that long
You said it's been doing this for past 24 hours. What were you doing with it before then?
EE PAYG SIMs are deactivated after 6 months of chargeable non-use. You then have a further 3 months to call EE to reactivate it before it is lost completely.
@srichardson95 wrote:
@srichardson95
Please see EE hibernation thread which sounds like your problem.
I think this may be the problem. Thank you, i will call EE to reactivate
You don't just need to make a chargeable call to keep it alive. You could have just as well have topped-up and bought & used a pack. Have you?
Good Morning @srichardson95.
Please come back and let us know how you get on after speaking with our customer service team 🙂
Jon
