by AndrewB62 Contributor
Password on 4gee router
I try and change the password which is a auto prompt but nothing happens when I type new password and ideas
Re: Password on 4gee router
@AndrewB62  Have you logged in to the device as admin  and changed the default password and saved the new password.  ?
Hi yes this is where it stick I enter old password(default) and the enter a new password and confirm then save and this is where it stops nothing happens
Best regards
Andrew
Sent from my iPhone
EE Employee
Hi @AndrewB62 and welcome to the community.
Could I ask you to try a master reset of the device and then try the process again?
Does this help?
Many thanks,
Lee
