by Artyb Investigator
PAYG data sim not activating
Brought a 6gb data only sim off amazon month or two ago, put in my unlocked tplink mifi but it won’t go to the activation page. Have tried it on different deceives. Any ideas appreciated
10 REPLIES 10
Re: PAYG data sim not activating
PAYG SIMs don't need activating. You sure it wasn't 6 months ago or so?
Hello there @Artyb
If you give us a call on 07953 966 250 the team will be able to look into your account and help you with this.
Thanks, Leanne 🙂
Are you in UK?
Yep I’m in the uk
It was less then 6 months ago
Can you browse to http://add-on.ee.co.uk/status ?
Can’t get anywhere on the web. The connection is good between the mifi and deceive but there’s no connection out through the sim.
Probably the TP-Link needs its APN set for EE. Try using the main settings from https://community.ee.co.uk/t5/4G-and-mobile-data/EE-APN-settings-Where-to-find-them/m-p/132083 .
by Jjsummerz
My sim won’t activate just got a new phone yesterday and my number won’t be recognised either and it’s the same one on my sim packaging
Morning @Jjsummerz
is this a new SIM card?
Is your new phone an upgrade?
Speak soon, Leanne 🙂
