by jacko183
New Member
PAYG Free boost problem. "Zero packs to go / -1 packs away"
I'm on a £10 PAYG pack. At the end of January I was 1 pack away from my next free boost. I topped up and bought my next pack. As expected I was told I was eleigable for a free boost and so I chose extra data. At this point the system should of reset meaning I should of been back to 3 packs away from my next boost.
Now, at the beginning of March, I have topped up again and bought my next pack. The free data boost I chose at the end of January went onto my balance just fine. Having bought this pack, my expectation is that I should now be of course 2 packs away from my next boost.
However for some reason when I text BOOST to 150 to find out, it says I am "-1 packs away" and when I check online it says "zero packs to go". There is obviously some sort of glitch and I'm worried once I've bought my next 2 packs and should be eligable for my next free boost, I won't get it.
I spoke to customer services on 150 and as nice and helpful as they tried to be, I don't think they understood the situation and I was getting confused myself.
Can anyone offer some help please? Would it be best to speak to someone in store?
Thanks.
EE Employee
Re: PAYG Free boost problem. "Zero packs to go / -1 packs away"
Hi and welcome to the Community @jacko183
I understand your frustration with this issue.
I would advise giving customer services another calling and asking them to perform a network refresh.
If this does not resolve your issue, they will need to raise a Single User Fault.
Another user is going through the same procedure to have this rectified.
Many thanks,
Lee
